I'm not sure if any of the street cars ever came with HR heads, although I would think Shelby would install any engine you wanted. Although it was a CSX30## car, the car I was told about was I think a comp car, not an S/C. I can't remember if the guy I talked to knew or told me if it came with aluminum or iron HR heads.
I have the HR single four intake, and the correct Lemans carb #3255-1.
I know the owner of CSX3106, and he has it set up with a stock stroke 427 CO, with the DOVE Paquet port HR heads ( basically a HR intake port with the floor raised to reduce the size to a med riser size). He epoxied (filled in) the intake runners of the single four intake to match the heads. 13:1, dry sump, 670 honest hp. He took me for a ride. That car is fast.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
