Old 03-28-2004, 09:58 AM
MrMagoo's Avatar
MrMagoo MrMagoo is offline
Cobra Make, Engine: Performance Cars Venom 427 Keith Craft 408 Stroker
Send a message via AIM to MrMagoo
Points ignition systems can easily be replaced, and probably should. I have a Mallory Unilite distributor on my 351W, with a Mallory promaster e-coil. I use the fatty 8.8mm Accel 300+ wires. Wires are like garden hoses, the fatter they are the lower the "pressure" and less chance for voltage leaks and cross-firing. The Uniite is opto-electric, no points or condenser, no dwell adjustment, etc. Check the plugs for weirdness as has been said, but consider a few hundred bucks for the switch.
If I can see you, I'm too close
