Old 03-28-2004, 05:37 PM
Dan Semko's Avatar
Dan Semko Dan Semko is offline
Hoosier Gashole Emeritus
Charly,
Gary Osborne had a similar annoying squeek that drove him crazy. After lubricating the rear bushings, the sway bar bushing etc we finally isolated it to the bushing under the trans mount. The bushing has a metal sleave that had worn through the rubber on the bottom surface causing a metal to metal contact. Try putting your car on a 4 post lift. While you're rocking it up and down, have a friend under the car and place a long flat headed screwdriver on each side of the trans mounts. It will be obvious if that's the problem. If it is, loosen the bolt, use a bottle jack, lift the trans slightly When you pull the bushing out, you immediately see the bare metal area. Place a large rubber washer ( like the one you'd find in a toilet filler replacement assembly) between the surfaces and retighten snuggly.
DDS/The First Edition
"In debates on ethically contentious issues, it is never wise nor polite to deride or belittle another person's delusion."
