Old 03-29-2004, 10:07 AM
edwhite7 edwhite7 is offline
Cobra Make, Engine: Contemporary, Shelby Alum 427, Dove heads
I do not use the bypass hose
I used the same alt. brackets and motor mounts from my iron block.
I got a high torque gear drive mini starter from Summit. Its not in the catalog but they have it.
The only problem I had was that the crank hit the block when I first ran it through before attaching the rods. I needed to remove some material from the block and it was ok. This was a common early problem and should most likely be fixed on your block.
