Old 03-29-2004, 06:07 PM
southernfriedcj southernfriedcj is offline
Originally posted by David Kirkham
Jim,
The size of the "allen" wrench we use on the 5/8 socket head cap screw for the rear lower control arm is 1/2 inch. Maybe you should check your size again. I don't think a 7/16 "allen" wrench will work.
We use "allen" head bolts because they give better clearance around the gas tank.
Please let me know if you have any problems.
David
David, I checked the cap screw again, this one isn't a 1/2". I'll have the 7/16 wrench in from NAPA tomorrow, and let you know how it goes. Also, this cap screw isn't near the gas tank(lower control arm -to- frame bolt).
Between the right rear knockoff and this cap screw, I'm starting to get the itch for a little oxy/ace!
