If you have the bolt-in trans bracket, I've found it simplest to support the transmission, unbolt the bottom mount bolt and unbolt the bracket, then jack the rear of the motor up slightly...pull the four trans/bell housing bolts and slide it out (this assumes you've already taken out the tunnel, of course). Without the bolt-in bracket, I'm not sure, you might have to remove the rear mount to make room to pull it...
Ken
