Old 04-01-2004, 06:23 AM
Mike Hausner Mike Hausner is offline
Club Cobra Member
Cobra Make, Engine: CLASSIC ROADSTERS 427 with a FORD 5.0 bored and stroked to 331cid, BRODIX alum heads, roller rockers, B303 cam.
ZYG,
Look for "352" cast into the drivers side front (passengers side down under) of the block. This was started with the introduction of the 352 engine in 1958. The 332s were only produced in 1958 and '59. If you have an early block the best way is to pull a cylinder head measure the stroke: 3.30" for the 332 & 3.50 for the 352. Both engines have a 4" bore. The early blocks and the police interceptor engines were designed to use mechanical lifters only because they didn't have the oil galleries to supply pressure for hydraulic lifters.
Good luck
MH
