When I come to a hard stop, the fuel in the bowls sloshes a bit and the rpm slows way down, almost to the point of stalling. I'm not sure if it actually would stall, b/c I always blip the throttle a bit before it can stall, but it is annoying.
The carb is a Mighty Demon 750 with mechanical secondaries.
Is there anything I can do to stop the fuel from sloshing in the float bowls and prevent this from happening?
(And yes, the floats are adjusted perfectly and the needles are not sticking. Triple checked
