04-01-2004, 03:02 PM
Club Cobra Member
Fl
Cobra Make, Engine: CLASSIC ROADSTERS 427 with a FORD 5.0 bored and stroked to 331cid, BRODIX alum heads, roller rockers, B303 cam.
The 332 and 352 engines would rev higher than the 390 & 427. Since the cranks rod and main journals are the same size you can swap the 332s 3.30" stroked crank for a 3.78" stroke 390 crank. With the 332s bore at 4.00" (same as the 352) you would have something less than 390 ci. The 361 & 390 bore was 4.05". You would have to use 390 rods too.
