Old 04-01-2004, 03:01 PM
TerribleTed13 TerribleTed13 is offline
Cobra Make, Engine: Johnspeed,408W,Tremec 600 roadrace, Liquid Yellow w/Black stripes
Silk, The carb boils over,engine is flooded. Do you have winter fuel?I have the same kind of problem with my Holley carb. Try a spacer between the manifold and carb,to help disapate heat. Is your fuel pump manual or eletric? Does the electric have an "on" toggle switch? Turn off the fuel pump 1 block before your destination.
