Old 04-01-2004, 11:41 PM
Keithc8 Keithc8 is offline
Default 427 Side-oiler engine for 11,000.00
I have a 68 427 side-oiler block that is .040 over with 3 sleeves to repair the block where it had cracked on the deck. The block has never been cracked or welded anywhere else. Never windowed or lost a rod in the bottem end.
I have a 428 CJ crank and rods with Aries pistons for the block that I plan to build complete ao that I know that everything is ok. The block has been pressure checked as well.
We are going to sell this as a complete engine of the dyno, tested and tuned ready to go for a bargain. I have the Dove/Comp Cams roller rockers, hydraulic roller camshaft with crane lifters, aluminum front cover, new damper, Edelbrock water pump, our Edelbrock CNC stage 2 heads with a Ford police interseptor intake. I will have a Canton T-style oil pan with melling HV oil pump, new Deamon carburetor, new Unilite distributor with MSD 8mm wires. I will allow 150.00 for valve covers as well, this will cover the FordRacing or Shelby valve covers.
Engine complete and ready to install in car. All you will need to add will be the starter, alternator and brackets, pullys with your coil. Most all of these parts are new except the block, crank, rods, front cover and the intake.
I am offering this one time special to move some inventory and build someone a nice little engine. This engine should make between 500 to 550HP and tourqe depending on camshaft and compression used on pump gas with no problems.
The price of 11,000.00 gets this complete deal. Thanks Keith Craft
Keith C
