Thread: Windsor Engine
Old 04-02-2004, 04:00 AM
boxhead's Avatar
boxhead boxhead is offline
If it is very tight to pull out, then you can find a steel bar, or pin punch that is a nice close fit inside the tube, then grab the tube where the bar, pin will prevent you from crushing it, hold tight with pliers and twist as you pull it up.
Cruising in 5th
