Thread: Brake Bleeding
Old 04-04-2004, 05:05 PM
Terry Stapley's Avatar
Terry Stapley Terry Stapley is offline
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
Default Brake Bleeding
I am having a heck of a time getting decent brake pedal pressure on my Shell Valley. I have done everything that I can think of.
My Cobra has two systems, a front and a rear. I started with the front and did not get much pedal pressure at all and called SV and they said to bleed both systems so the bias would not come into play. I then bled the rear system and now I have some pedal pressure but you have to pump the heck out of it to get it to feel close to correct. Any help would be greatly appreciated.
I also tried a mightyvac vacuum pump at the wheel cylinders but got more bubbles than fluid.
Terry
