Terry,
I had the same identical problem and tore my hair out trying to come up with a solution.
The cure... if you haven't already done it, disconnect the rear master cylinder rod from the pedal and bleed the front, then disconnect the front rod at the pedal, re-connect the rear to the pedal and bleed the rear (always bleed from the valve the furthest from the m/c and work toward it. I used vacum bleeders, pressure bleeders, etc. When you adjust the bias 70-80% of the pedal pressure should be on the front brakes.
Good luck.
Phil
http://www.uniquecobra.com/
