Pete, run a lower gear in back which will allow it to crank up quicker and you might avoid pinging. Also, you could run less total timing to avoid pinging. I personally would rather have the compression and run less total timing. That way, if you are ever at the track, you can add timing and race gas and the motor will gain a bunch of power. Scott
