Check out this site:
http://www.apexperformance.net/secur.../c76206.2.html
They sell a number of MOTIVE model pressure bleeders. I bought a model for around $89.00 that came with every adapter known to man. It is a relatively simple operation to bleed with this set up. You just use the adapter that fits the master cylinder being bleed, make sure you have a good seal, pump the handle on the unit until the prescribed pressure shows on the gauge and open the bleed screws on the calipers connected to that master, one at a time. Check to see that you don't let the pressure in the main canister drop too low. When you get a steady stream of fluid, the job is done. You don't need to touch the pedals and you can do it all alone.
Hope this is helpful
JL1924
