Old 04-07-2004, 11:08 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Doug, I don't think such an animal exsists. One pull on a dyno will show rpm, horsepower, and air/fuel as well as torque. You would have to make a jet change in the carb and then do another pull and check air/fuel vs hp...and that's with all other variables remaining constant. There is a very thin line between making max hp and meltdown, that's why most run rich for the street and not max hp. For detonation you also have heads, compression ratio and timing variables. Other than comparing different dyno pulls, knowing what changes you made, I don't think you will find what you're looking for....
Jack
XSSIVE .....
