Thread: Fuel Issue
Old 04-07-2004, 02:52 PM
PCC's Avatar
PCC PCC is offline
Alvin,
Will post some pics later.
After retightening all my clips I did notice the top breather clip was loose so will monitor over the next few days.
Definitely no other leaks anywhere else.
I have the aluminium cover plate to the tank - does not look pretty, but at least is out of sight.
The other idea may be a bloked breather hose. I'm told that after a good run if the filler cap is under pressure when removing then the breather is blocked.
Its my fuel consumption that I am concerned with - 400km tops per tank - may be city driving, but definitely not as good as 2 months ago.
Will check out the oxygen sensors, but again I'm told they only kick in on a long run.
If the fuel consumption / petrol smell remains over the next few weeks its back to my engine tuner for a checkout and fix.
This perfection thing is a pain in the a#$e!!
PCC (Peter Craig)
Keep the sun shining
