Old 04-07-2004, 03:33 PM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Smile Forgot one thing.......
Hi,
even with the wide band oxygen sensor it is going to read richer and richer as the duration of your cam increases. If you then try to lean out a motor with a big cam , it really won't work,you're going the wrong way. You actually have to read the plugs or measure the changes on a dyno or dragstrip, the meter isn't going to help with dirty cams.
Perry.
