Old 04-08-2004, 12:27 AM
Ant Ant is offline
Default Original Cobra Hub face to Hub face Measurement?
Can anyone help me with a ballpark measurement of the original front suspension Hub face to Hub face, that is where the back of the wheel touches the pin drive flange, of either the Trigo adapter or original six pin hub.
Also approx length of suspension arms from inner pivot to center of ball joint, as I have a wheel hitting guard problem with a 235/60-15 Bridgeston 340 Eager (I have only borrowed this new tire, but its the approx right diameter of 26.3") and its cross section is 9.5" which interferes with guard.
My aim is be able to import Goodyear slicks from either Roger Krause or Goodyear, else use Hoosiers which are readily available in this country, but they all seem to have wide cross section on a 7.5" wheel of around 10.4" thats the buldge of the tire!!
Having said all that my car has original style body taken from an original and original dimension offset Trigo wheels.
A J. Newton
The 1960's rocked!
