Old 04-08-2004, 03:05 AM
grumpy grumpy is offline
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
Default suspension
force8,
Am I correct in, you have a bare KMP frame (of early sequence) and you need full front and rear suspension?
Have you did anything on the brakes, like select brand, sizes, purchase, etc. that will greatly effect what you can do as far as the existing frame points since you will need spindles both front and rear, and "custom" ones are VERY EXPENSIVE.
It will also effect your dual master cylinder selection, will the replacement ones you are using work with the calipers, etc. and so on?
grumpy
