Grumpy, Thanks for the quick post. I haven't done or bought anything. Your correct in your assumption of the bare frame. I have no suspension parts. It is the main frame rails with all the 1 in. sub framing, all the proper mounting points, cross members, etc. I like the Wilwood 11 in. brake system for the front and
AMB (?) set up on the rear, but would use stock Girling if I had to. As for master cylinders, Wilwood or stock, as I haven't bought either. All I have is the above described frame and an early CSX 4000 fiberglass body, with 2 doors, hood, trunk, foot boxes, trunk tub and the aluminium sub panels. Mike
