Old 04-13-2004, 07:40 PM
MidOHasp MidOHasp is offline
Cobra Make, Engine: SPF1670 Stroked Little Windsor - Runs OK.
Send a message via AIM to MidOHasp
Unhook fuel line from carb, run into quart gatorade bottle. Just assuming that might be the easiest answer. That's how I primed my fuel line and made sure the tiny rubber and stainless bits that went in the tube from cutting it w/ a whiz-wheel were completely out.
Depending on your fuel line setup that may be a pain in the butt, but if it's easy, that's probably an easy solution......
Just my $.02
J.P.
Ohio Cobra Club
Token Gashole
