Old 04-14-2004, 08:34 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Smile
Loosen up the linkages.
Put everything in neutral.
Slide a 1/4 inch drill bit into the 1/4 inch hole in the lever arms. (Just below the big round pin with the spring on it.)
When all of the arms line up through the hole, tighten up the linkage.
PULL OUT THE 1/4 INCH DRILL BIT.
Your linkage is now adjusted properly.
David
