The only thing I will be able to get here fast is the stainless steel wool used to clean metal pans and bowls.
I can push them down the four pipes of each header and hook them up to a stainless steel wire long enough so I can pull them out again. I suspect that the pads will end up beeing pushed way into the muffler section and not come out any more.
I am trying to make a little basket filled with steel wool and join it to a long hook to be pushed in from the exhaust side to engage somewhere inside perforated tube inside the pipe. That shoul hold the steel wool basket in place.
I would appreciate any comment on this.
One tip a friend gave me is to go to the inspections in summer when the air is hot. With hot air apparently the exhaust noise gets muffled somehow.
Nothing sounds better than a Cobra in a Tunnel !
