Old 04-18-2004, 07:31 AM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
Sounds like a bad booster or a leaking check valve. Have you tried unhooking the vacuum line and driving the car? Chances are the engine will run fine. That will show you have a leak in the booster system. Some of them will only leak when the pedal is pushed past a certain point. When you step on the brakes with the engine running can you here any vacuum leaks? A whistle sound?
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
