Old 04-18-2004, 08:38 PM
TerribleTed13 TerribleTed13 is offline
Cobra Make, Engine: Johnspeed,408W,Tremec 600 roadrace, Liquid Yellow w/Black stripes
Post
Trueoo7,
No that lobe should not have any play! That is the fuel pump eccentric and is held to the camshaft with 1 bolt. Its more like a pulley that has a small tab that extends to keep it in place. You need to pull the timing cover off, and use red locktight on that bolt to make sure it dosen't come loose. The rest of the valve train will be fine, as your inspection showed. The instructions indicate to have the lobe on the low point, so your not fighting the fuelpump arm spring during installation. Just "bump" the engine around so the fuelpump slips into position. But you may want some pointers on the removal and installation of the timing cover.
