  #21 (permalink)
Old 04-19-2004, 02:13 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Originally posted by cobra
Eljaro
I mounted Vortex Insert cones with very good results. ( http://www.secureperformanceorder.co...ore/vortex.cfm )
Regards, Walter
Walter,
Where in your sidepipe did you mount the cone? Looking at the picture on the link you provided, it looks like they are designed to go right after the collector, but that means cutting and welding- and I don't have a welder. Did you simply slip them into the end of the sidepipe and fix them in place there?
Thanks,
Mike
Replica is not a dirty word.
