Does that clutch arm have a 1:1 pivot ratio? If you have a master and slave cylinder of the approximatley the same size, you would need an arm that had a 2:1 ratio. You want somewthing like 1 inch travel at the master cylinder to wind up as 1/2 inch of throwout bearing movement.
