Old 04-20-2004, 06:05 PM
grumpy grumpy is offline
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
Default Rear Design
Iggy,
The rear design is just as cost effective to go with the IRS. The number or stainless forged urethane joints cost that of a 5 link live axle when you figure in the better grade w/ poly jackets for keeping out the grit, due to the loading.
If I even thought of a small block it would be a 351W that I later swapped for a 392 stroker of that type. Now if you're going to build a REPLICA 289 Comp version or FIA, then a small block for sure.
Did not receive your eMail, or would have sent the stainless pics you wanted.
grumpy
