Old 04-21-2004, 08:34 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
What ever you do to them you are going to have to re-bleed your brake lines in the front. You can loosen your flex brake line at the place where on the frame where it adapts to the hard lines and rotate your flex brake hose so it clears both objects. Re-tighten the brake line and bleed your front brakes again. I hope this makes sense because that is what I had to do and it worked.
Clois
"Let's roll"
"Be part of Something Good
