Old 04-21-2004, 01:15 PM
SFfiredog SFfiredog is offline
Default 482ci tunnel port horsepower numbers
Hi Guys,
I just dynoed a 427 I built for a friend's Cobra.
Here are the specs:
483 ci tunnel port
block: center oiler 4.25" bore
crank: 391 truck forged steel, welded and offset ground 4.25"
rods: Oliver forged 6.700"
pistons: CP inverse dome 10.38 to 1 compression
cam: custom Comp Cams flat tappet "tight lash" 252/260 dur @.050 .616" lift int/exh
112 l/c installed at 108 i/c Schubeck flat tappet composite lifters
heads: factory iron tunnel port, ported by me
intake: factory 8V single plane
carbs: Demon 725 cfm vac secondaries 1" spacers
ignition: MSD billet dist with 6AL
2" primary, 4 inch colletor boat headers
HP 572 @ 6000 rpm TQ 533 @ 4800 rpm
1-3/4" primary, 3" colletor street headers
HP 565 @ 6000 rpm TQ 568 @ 4400 rpm
Superformance headers and sidepipe mufflers
(1-7/8" to 2" primary to sidepipe mufflers)
HP 548 @ 6000 rpm TQ 506 @ 4500 rpm
As you can see, the Superformance sidepipes didn't hurt HP as much as TQ (60 ft. lbs.)
All pulls were made on crappy California 91 octane unleaded pump gas
Timing was set a 37 degrees total
The engine idles at 850 rpm with 10" vacuum
The engine kept making more power on each pull because the rings were seating.
The dyno time was limited but I'm sure there is more power to be found with other minor changes.
It should be a fun, reliable street motor.
--Mike
They bend 'em, we mend 'em.
