Old 04-22-2004, 09:49 AM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
I got the powermaster too. I'm also at 11:1 and it seldom turns half a turn before it fires. I did not like the way my powermaster had the terminals (there are two) facing the block at first. But in retrospect it worked out better. Clearance to the side of the block is pretty tight and even tighter to the block directly above the starter. I ended up using a longer (32") cable to mystarter selinoid. The first time I mounted the starter I directed the shorter starter cable toward the selinoild as the OEM starter had been. In this direction the cable hit the block. I ended up rotating the cable to the frontand turning it to run down the side of the starter behind the bell housing and well away from the headers. It made for a very clean installation.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
