Old 04-22-2004, 04:04 PM
CSX 4027's Avatar
CSX 4027 CSX 4027 is offline
Cobra Make, Engine: Sold 3047 & 3002 in 2012
Default oil cooler
An oil cooler on the steet is usually more of a negative than one would think. You need hot oil for the bearings to survive in your motor. Especially with heavy weight oil. For the track is a different story. Spend an hour at speed at a track and you will understand what I mean. As most use -12 lines to look original, I would suggest blocking off the cooler with cardboard and duct tape until the oil gets warm. Also, use a oil pan heater stick on pad made by Moroso. It saves engines. No cold start ups. All the "Cup" guys use them. There is most definately a reason to use one. Cheap Insurance.
Steve Sunshine
www.competitionlife.com
"Hurry Up And Live"
