Carb Leaking
My 7 month old Edlebrok 650 cfm Carb has developed a leak. A small drip of fuel is dripping into the primary chamber from the needle valve adjustment causing the idle to vary from 900-1500rpm. If you look into the carb you can see a small drop of fuel every few seconds leaking.
joeg
