T56 Wiring
HI DON OR ED
MY T56 TRANSMISSION HAS NO NEUTRAL SAFETY SWITCH.
CAN I USE WIRES #121 & #126 FOR MY VSS ( VEHICLE SPEED SENSOR ) ON MY TRANS, IF I CUT THE WIRES #121 & #126 BETWEEN THE FUSE BOX AND THE TERMINAL BLOCK FOR THE STERING COLUMN? THEN WIRE #121 & #126 FROM THE STERING COLUMN TO A CLUTCH PEDAL SAFETY SWITCH AND #121 & #126 FROM THE FUSE BOX TO MY SPEEDOMETER?
THANKS BOSS MIKE
