Old 04-28-2004, 04:08 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
All kidding aside, I suggest you take the car back to the person who put the belt on and indicate you are not satified with the repair.
If that is not an option, get your wrenches out and do the job. It appears the timing is off, probably a tooth. There is no adjustment for the problem if it is a tooth off.
Good luck, hope this helps.
