The ignition system is complete rewired today. But we've still got the same problem. While the engine is running he switches off by hisself,no spark anymore out of the ignition coil. When i check the stator assembly (purple and orange wire):698 ohms with hot engine. With cold engine is this :687 ohms. when i check the ignition coil (from plus 15 to 1 so the red and green wire)with hot or cold engine:3.8 ohms. also do i have 12 volts on the red wire during contact (on the ignition computer and on the ignition coil) and 0 ohms on the black wire (ground). During start do i have 10 volts on the ignition coil an the same voltage on the white wire on the computer. When i feel the temprature of the ignition coil or the computer during running,tis not extreme hot. The computer is replaced on a aluminium plate. When i let cool down the engine it starts normal en there's a spark. Whe've disconnected every safetyswitch.
