Old 04-29-2004, 08:21 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
arctic, the pedal box won't change in size. The proper configuration for the box is to use a 1974 to 1978 Mustang II booster. The box is setup to accept it without any modification. I don't know why someone would have cut and welded yours unless it's not from a Mustang II. I would definitely change it. You are putting a lot of trust in someone else's welding ability. The rod is a separate piece but not available unless you find a salvage yard unit. You should be able to bring the gas pedal up by shortening the cable unless it is a stock Ford unit. If it is I would change to a Lokar universal cable and bracket. It will let you set the pedal for full throttle by adjusting the cable. If you have enough room to the right of the gas pedal you can cut off the outside edge of the mounting tube and use it as a spacer to move the pedal to the right. I do use the AC pedal for the gas.
Don
