Thread: Noisy Fuel Pump
Old 04-29-2004, 09:51 AM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Default Noisy Fuel Pump
Hi,
I have a Holley (Red)out of tank electric fuel pump and the noise is starting to bother me. The pump is currently hooked up with hard lines. Holley suggested putting putting a short run of soft line before and after the pump so it doesn't transfer as much noise/vibration.
Do you think the soft lines will make much of a difference? Should I bother. Is there a quieter pump out there?
I guess I can always raise my idle to about 1200 rpm so I don't hear the pump.
Thanks
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
