Old 04-29-2004, 11:41 AM
arctic-snake arctic-snake is offline
Hi Don,
Thanks for the reply. I know you have a business to run and I do appreciate the time you take out of your schedule to help us out. The top end of the gas pedal is hard up against the firewall(when throttle is released), I have adjusted the cable as much as possible(it is a LOKAR). I can push the pedal until it hits the positive stop (adjusted down fully)on the firewall. I will look into an adjustable accellerator pedal or buy the AC pedal and bend it if needed to get the travel I require. The pedal offset I refer to is front to back,not the relationship across. The gas pedal is about five inches deeper in the footbox than the clutch/brake pedals. Looks like my booster needs to be changed out either way. I'll be waiting for news on the new brake pedal.
Thanks again
