OK. Got the right cable (Napa) and the pedal / sleeve from CR. The cable, as with all mustang cables, has the L shaped bracket. Do you guys use this bracket or just cut it off and make a new bracket. Seems like the L shaped bracket is made for a flat surface. Not sure there is a flat surface available. I was thinking of cutting the L off and attaching the cable with clamps in two locations to prevent movement. Also, the cable runs pretty close to the header. I have mine running between the motor mount and header.
