If you are using a early style fork you may wish to go to a late style. It pivots from the other side and will give a bit more leverage at the plate. Also you need to use a master and slave cylinder the right size for the clutch you are using. Are you pushing the fork or pulling it?
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
