Old 05-02-2004, 04:11 PM
grumpy grumpy is offline
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
Roxie,
The FFR plans don't even fit the FFR contours, so with a double strip of HVAC large foam insulation stapled to it it should get close enough to support it fine.
On the Shell valley be sure and support the rear bulkhead arc and the dash cowl area, you don't want it to take set at the wrong arc. You don't want to get a case of "perky butt".
grumpy
