Old 05-03-2004, 05:54 AM
TC Cobra's Avatar
TC Cobra TC Cobra is offline
Cobra Make, Engine: Classic Roadsters; 351w, Crane Cam, AFR 185's
Well, the good news is the wiring is "finished". The bad news is it's not right >:-/
1. #151 (power to the fan relay) is not energized when the ignition is on. There are two other unused switched sources: #127 & 130. Any reason I can't use either of those to power the fan relay?
2. In a thread above you mentioned teeing off the fan temp sender wire to the override switch and connecting to the other side of the red dash light. When I do that, the fan is always on. Checking the other wire I found it is grounded. That can't be normal (?). If I disconnect the wire to the light everything works OK.
3. None of the guages (voltmeter) work. #130 seems to be grounded.
4. I do have dash lights and the headlight and tail light sockets have voltage.
Any thoughts?
Thanks!
