Old 05-03-2004, 08:08 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Dwain, it sounds like you have a ground problem. Run a separate ground from the cowl bar to any of the grounds on the dash harness. That should take care of most of the problems. Wire 151 should have ignition power, I would check the fuses, make sure you have one in the fan slot. Let me know what happens.
Don
