Don,
I've read all the discussions here about bad grounds causing problems so I've probably "over-spec'd" my grounds. I have a 12 ga wire with several connectors, connected to the cowl bar, that I've attached all the ground wires directly to.
All the fuses are good.
It's wierd that #'s 127 & 130 on the "left over" connector seem grounded when the key is off but test 12 volts when the key is on.
I don't know what to say about #151. I ran a wire from a good connection through the firewall and... nothing. I didn't test it before - I wasn't that far along. Is there something special about 151 that 127 can't substitute?
What now boss?
