Old 05-03-2004, 12:16 PM
coyled coyled is offline
Ernie, I broke 2 rear hubs because the bearings were likely never adjusted properly. You might have broken hubs. They generally won't loosen up to the point where you can feel the kind of play you are taliking about. Once you have the correct spacer, you tighten the nut to 140 foot pounds. Any looseness will cause radical toe changes and yes its scary. Good luck, Scott.
