Old 05-03-2004, 04:01 PM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Oinie - the play could be in the bearings, but check as well the bottom hub pivot bearings.
Also, if the diff output shaft bearings are on their way, this also can feel like wheel bearings.
Rarely seen a jag rear end without some play in it.
Don't forget the loctite on the splines when you are done.
Youv'e done these things before anyway, haven't you?
Wilf
