Old 05-04-2004, 06:12 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Okay, if you have a electronic Speedo, there may be a angled device connected where the speedo cable would go, That is a transducer. If it has wires instead of a cable that rotates, it is a transducer. It send pulses to the speedo at a rate relative to the rotation of your tail shaft.
Kirkham is right about the gears, which beggs a question: Has this ever worked before?
Are you trying to connect a speedo that is electronic or mechanical ( cable driven )?
